EGAD! SD Letterbox Removal for SD Widescreen
Doug Metz
on Sep 10, 2008 at 8:08:36 pm
Greetings All,
I have an unenviable problem. Essentially, SD zoom to remove the letterbox for 16:9 output.
The source is a DV timeline in FCP. I've got an ioHD, a DSR-11, and an Ampex CVR-75 (same as BVW-75). Working on a current MacPro.
Is there some way to do a decent job of this with the gear I've got? I've tried to run the source out to Beta and upconvert while re-ingesting, but the results aren't what I was hoping for. I don't expect that scaling in FinalCut will look any better.
Any ideas?
Doug
Carsten Orlt
Re: EGAD! SD Letterbox Removal for SD Widescreen
on Sep 10, 2008 at 8:27:01 pm
haven't done it but isn't the following made for you problem?
Aja ioHD control panel > format tab > SD to SD options (bottom right in window) > (I think) you would choose H crop?
Carsten
Doug Metz
on Sep 10, 2008 at 8:50:44 pm
So that would be: out to tape -> ingest w/vertical crop @525i29.97 ?
Looks like that should be it - will post back w/results.
