*NEW* AJA Io HD v6.0 software available now
AJA Sales Department
on Aug 19, 2008 at 10:41:43 pm
Hello,
Available today at the Support section of our website is new version 6.0 software for the Io HD (as well as new v6.0 software for KONA, see details on the KONA page). New features and fixes include:
*Io HD New Features*
- Additional format support for true progressive formats in 1080
- Additional format support for intermediate formats
- Added Audio Delay for Input and Audio Delay for Output controls
- Stand Alone Mode enabled
- Io HD LCD display now allows users to choose between the display of primary and secondary video formats or the primary video format and timecode
- Io HD now a FireWire "plug and play" device (can now be connected or disconnected to host computer without rebooting to recognize device)
- Active Video Output Filter added
*Io HD Improvements and Fixes*
- Component and composite now provide simultaneous output
- General improvements to A/V sync performance
- General improvements for multi-user environments
NOTE: There is important configuration and installation information contained in the READ-ME for the Io HD software release, so please be sure to read it completely.
Io HD v6.0 software can be found here:
http://www.aja.com/html/support_Io_swd.html
As always, feel free to contact us with any additional questions.
Thank you,
AJA Video Systems
+1 (530) 274-2048 Intl.
(800) 251-4224 US
sales@aja.com
Jim Press
Re: *NEW* AJA Io HD v6.0 software available now
on Aug 22, 2008 at 5:24:57 am
Has anyone upgrade to 6.0 yet? Is it definitely stable? I'd like to upgrade so I don't have to reboot my Mac every time I plug in/out the Io, but I'm just a bit hesitant to change something that is fundamentally working...
Ken Botelho
on Aug 22, 2008 at 11:14:41 pm
I can say this is probably the biggest update the ioHD has received since the release, no problems here.....yet (running OS X Leopard)
Tim Allison
on Aug 26, 2008 at 1:16:21 pm
We were having SERIOUS audio/video sync issues when ingesting standard definition video from a Sony M25-U HDV deck via the HDMI ports. I did the upgrade and ingested about 5-6 clips as a test, and everything worked fine....audio and video were in sync.
gary adcock
on Aug 26, 2008 at 1:40:46 pm
[Tim Allison] "We were having SERIOUS audio/video sync issues when ingesting standard definition video from a Sony M25-U HDV deck via the HDMI ports. I did the upgrade and ingested about 5-6 clips as a test, and everything worked fine....audio and video were in sync."
did you make sure to Update the firmware in the IoHD also?
there was a firmware updater that had to be run to complete the Updating process.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Inside look at the IoHD
Jeff Mack
on Aug 27, 2008 at 3:59:45 pm
I've got a ton of 1080i 60 PRHQ. Anyone transcode yet to 1080p 30? How about anyone capturing 1080P 30?
Jeff
Will Griffith
on Oct 1, 2008 at 2:56:15 pm
We are getting audio only thru HDMI with version 6.1.
No Video sync light. Flickers for a moment with deck power on and then
nothing.
How do you have the M25-U and IO set up?
thanks
Will Griffith
Producer
Tim Allison
on Oct 1, 2008 at 4:32:48 pm
Will,
Pretty simple on my end. We are taking HDMI out of the M25U and going HDMI in to the Io box. Please don't let me insult you with this, but did you check the "inputs" tab in the Io Control Panel to make sure you have selected the HDMI video input? You must select HDMI for both audio and video.
I can't remember if there is anything I did to the menus in the M25U, so look through those to see if there is anything that needs tweaking.
Will Griffith
on Oct 1, 2008 at 4:37:21 pm
No insult taken. :)
It just isn't showing up.
HDMI in and HDMI "Audio Input" are both selected in IOHD
control panel but have red bars and "No Video" next
to the input.
Will Griffith
Producer
Will Griffith
on Oct 2, 2008 at 2:05:56 am
On the third HDMI cable and still no luck.
Weird thing is it worked once....then quit.
We converted a 30 minute show from DV to
BetaSP without a hiccup, and then just quick
recognizing again.
Really strange!
Will Griffith
Producer
