AJA ioHD and Sony BVW-70P, Can't Edit to Tape
Thomas Anthoni
on May 22, 2008 at 12:32:47 am
Hi everyone,
I'm totally new to the AJA and might have made some beginner mistakes. But I'm in a very difficult situation right now. I'm a filmstudent and I'm having trouble making a playout from FCP 6.0.3. The footage is HD720p25 (PAL) captured in Apple ProRes(not HQ). I have to dump it onto a Betacam SP tape with very specific timecodes, by tomorrow 12 am. I have the latest drivers for my AJA. I'll put the specifics from the info tab underneath this post.
Now here is what I tried, and what went wrong. Like the tought us in school, I first recorded 30 seconds of Bars and Tone onto the tape through crash record. This worked before, But now my FCP gives me this message. The selected audio and video devices may not match.
- AJO IoHD 625i25 8bit (720 x 576)
- Default
Strange part is that in my audio/video settings it is set to 720p50 ProRes 422 and AJA IoHD. Also pretty strange is that before I could do the crash record, now he even gives a new message telling me the tape could be locked of the device could be on local. Both isn't the case, so again a strange message from FCP.
But this are already new problems I didn't hade before and that I probably could resolve by reïnstalling. But even the first time, Edit to Tape didn't worked. He gave the message that the formats didn't matched so I couldn't do the edit. Now after a lot of changing settings, he gives another problem. When I type the inpoint at 1000, he gives 08;10. My friend said this were dropframes, he tried a lot to solve the problem, without succes. Now if I try to edit tape, I give an inpoint. He starts searching (the lights of the BVW-70P start flashing) but he never starts recording. FCP just crashes.
I already had a friend of mine look at it, without much succes. Now I can't even crash record anymore, something I could do before.
I'm panicing a little bit right now, so if I didn't gave enough info, just ask. Underneath you can find al the data from the info tab. Don't know if it would help.
Cheers
Hardware ID: IoHD (0x10224000) S/N IH004660
VideoProc Bit file: 2007/12/04 13:00:16 (DownConvert)
/Library/QuickTime:
5.1.1 - AJACodec.component
5.1.1 - AJADigitizer.component
5.1.1 - AJAMuxer.component
5.1.1 - AJAUncompressedCodec.component
5.1.1 - AJAVideoOutput.component
5.1.1 - AJAVideoOutputClock.component
5.1.1 - AJAVideoOutputCodec.component
1.5 - FCP Uncompressed 422.component
1.4 - DVCPROHDCodec.component
1.2 - AppleIntermediateCodec.component
1.4 - AppleHDVCodec.component
1.0.2 - AppleProRes422.component
/Applications:
5.1.1 - AJA ControlPanel.app
/Applications/AJA Utilities:
5.1.1 - AJA Conflict Checker.app
5.1.1 - AJA Data Rate Calculator.app
5.1.1 - AJA DPXToQTTranslator.app
5.1.1 - AJA IoHDUpdater.app
5.1.1 - AJA QTToDPXTranslator.app
5.1.1 - AJA System Test.app
5.1.1 - AJA TV.app
5.1.1 - AJA Uninstaller.app
/System/Library/Extensions:
5.1.1 - AJAIoHD.kext
/Library/LaunchAgents:
11/21/2007 00:10 - com.aja.ajaagent.plist
/Library/Application Support/AJA/AJAAgent:
02/14/2008 03:33 - AJAAgent
/Library/Application Support/Final Cut Pro System Support/Plugins:
02/14/2008 03:42 - AJA Kona RT Enabler
/Library/Application Support/Final Cut Pro System Support/Custom Settings/IoHD Easy Setups:
09/28/2007 23:47 - AJA IoHD- 1080i 25 Apple ProRes 422 (HQ).fcpre
09/28/2007 23:47 - AJA IoHD- 1080i 25 Apple ProRes 422.fcpre
09/28/2007 23:47 - AJA IoHD- 1080i 25 Apple ProRes to 10 Bit Uncompressed.fcpre
09/28/2007 23:47 - AJA IoHD- 1080i 25 Apple ProRes to 8 Bit Uncompressed.fcpre
11/09/2007 00:10 - AJA IoHD- 1080i 25 Apple ProRes to DVCProHD.fcpre
09/28/2007 23:47 - AJA IoHD- 1080i 29.97 Apple ProRes 422 (HQ).fcpre
09/28/2007 23:47 - AJA IoHD- 1080i 29.97 Apple ProRes 422.fcpre
09/28/2007 23:47 - AJA IoHD- 1080i 29.97 Apple ProRes to 10 Bit Uncompressed.fcpre
09/28/2007 23:47 - AJA IoHD- 1080i 29.97 Apple ProRes to 8 Bit Uncompressed.fcpre
11/09/2007 00:10 - AJA IoHD- 1080i 29.97 Apple ProRes to DVCProHD.fcpre
09/28/2007 23:47 - AJA IoHD- 1080psf 23.98 Apple ProRes 422 (HQ).fcpre
09/28/2007 23:47 - AJA IoHD- 1080psf 23.98 Apple ProRes 422.fcpre
09/28/2007 23:47 - AJA IoHD- 1080psf 23.98 Apple ProRes to 10 Bit Uncompressed.fcpre
09/28/2007 23:47 - AJA IoHD- 1080psf 23.98 Apple ProRes to 8 Bit Uncompressed.fcpre
11/09/2007 00:10 - AJA IoHD- 1080psf 23.98 Apple ProRes to DVCProHD.fcpre
09/28/2007 23:47 - AJA IoHD- 720p 23.98 Apple ProRes 422 (HQ) Varicam.fcpre
09/28/2007 23:47 - AJA IoHD- 720p 23.98 Apple ProRes 422 Varicam.fcpre
10/01/2007 18:06 - AJA IoHD- 720p 23.98 Apple ProRes to 10 Bit Uncompressed Varicam.fcpre
09/28/2007 23:47 - AJA IoHD- 720p 23.98 Apple ProRes to 8 Bit Uncompressed Varicam.fcpre
11/09/2007 00:10 - AJA IoHD- 720p 23.98 Apple ProRes to DVCProHD Varicam.fcpre
09/28/2007 23:47 - AJA IoHD- 720p 25 Apple ProRes 422 (HQ).fcpre
09/28/2007 23:47 - AJA IoHD- 720p 25 Apple ProRes 422.fcpre
09/28/2007 23:47 - AJA IoHD- 720p 25 Apple ProRes to 10 Bit Uncompressed.fcpre
09/28/2007 23:47 - AJA IoHD- 720p 25 Apple ProRes to 8 Bit Uncompressed.fcpre
11/09/2007 00:10 - AJA IoHD- 720p 25 Apple ProRes to DVCProHD.fcpre
11/17/2007 00:12 - AJA IoHD- 720p 50 Apple ProRes 422 (HQ).fcpre
11/17/2007 00:12 - AJA IoHD- 720p 50 Apple ProRes 422.fcpre
11/17/2007 00:12 - AJA IoHD- 720p 50 Apple ProRes to 10 Bit Uncompressed.fcpre
11/17/2007 00:12 - AJA IoHD- 720p 50 Apple ProRes to 8 Bit Uncompressed.fcpre
11/17/2007 00:12 - AJA IoHD- 720p 50 Apple ProRes to DVCProHD.fcpre
09/28/2007 23:47 - AJA IoHD- 720p 59.94 Apple ProRes 422 (HQ).fcpre
09/28/2007 23:47 - AJA IoHD- 720p 59.94 Apple ProRes 422.fcpre
09/28/2007 23:47 - AJA IoHD- 720p 59.94 Apple ProRes to 10 Bit Uncompressed.fcpre
09/28/2007 23:47 - AJA IoHD- 720p 59.94 Apple ProRes to 8 Bit Uncompressed.fcpre
11/09/2007 00:10 - AJA IoHD- 720p 59.94 Apple ProRes to DVCProHD.fcpre
09/15/2007 23:21 - AJA IoHD- NTSC 10 Bit Uncompressed.fcpre
09/15/2007 23:21 - AJA IoHD- NTSC 8 Bit to DV.fcpre
09/15/2007 23:21 - AJA IoHD- NTSC 8 Bit to DVCPro50.fcpre
09/20/2007 00:11 - AJA IoHD- NTSC 8 Bit Uncompressed.fcpre
09/28/2007 23:47 - AJA IoHD- NTSC Apple ProRes 422 (HQ).fcpre
09/28/2007 23:47 - AJA IoHD- NTSC Apple ProRes 422.fcpre
09/18/2007 00:44 - AJA IoHD- PAL 10 Bit Uncompressed.fcpre
09/15/2007 23:21 - AJA IoHD- PAL 8 Bit to DV.fcpre
09/15/2007 23:21 - AJA IoHD- PAL 8 Bit to DVCPro.fcpre
09/15/2007 23:21 - AJA IoHD- PAL 8 Bit to DVCPro50.fcpre
09/15/2007 23:21 - AJA IoHD- PAL 8 Bit Uncompressed.fcpre
09/28/2007 23:47 - AJA IoHD- PAL Apple ProRes 422 (HQ).fcpre
09/28/2007 23:47 - AJA IoHD- PAL Apple ProRes 422.fcpre
Possible conflicting QuickTime components:
No conflicting files found.
Jeremy Garchow
Re: AJA ioHD and Sony BVW-70P, Can't Edit to Tape
on May 22, 2008 at 12:21:45 pm
Follow these instructions but replace the format/frame rate that are specific to you (ie, everything PAL). Also, choose the ioHD easy setup instead of LHe setup. It works exactly the same way:
http://forums.creativecow.net/readpost/98/869819
Jeremy
