Aja io vs io HD
Dave Nadal
Aja io vs io HD
on Mar 7, 2008 at 12:50:10 am
Hello, I have a reduced budget, and I see that AJA io and aja io HD are more similar. HD have a prores422 compression but with io model I think that I will capture with normal resolution of my panasonic ( DVCPRO HD ) and compress with FInal cut pro 6. Is it correct? The quality of compression is the same of ioHD ? for reduced price do you recomment IO version or ioHD has more quality ad da and options ? Thanks and greetings
John Pale
Re: Aja io vs io HD
on Mar 13, 2008 at 4:30:36 am
The standard iO does not work with HD. Standard def only....so no DVCPRO HD
