AJA Io La workflow advice
Tim Toidze
on Feb 29, 2008 at 9:07:21 pm
I just got an AJA Io La card and I urgently need to digitize a few Betacam SP PAL tapes (I will have them till Monday). I work on FCP and the desired codec is ProRes HQ (I have to provide a hard drive with the video in this codec).
My problems:
Well, first of all I want to have the best quality digital copy possible, so I want to be sure that everything is foolproof before I start digitizing.
Second of all, I need the original Betacam Time-code and I can’t seem to get it.
Third of all, I want to control the J-10 (I should be able to via Rs422 connection, but it doesn’t seem to work).
If somebody can have a look at my workflow and say what I am doing wrong, I would be very grateful. Thanks!
Sony J10 is connected to Aja Io La.
Component:
Y – Y/G
R/Y - Pr/R
B/Y – Pb/B
External Sync – Ref Loop
Rs 232 to RS 422
ProIO Control Panel settings:
Preset 1
Video Input: Analog
Video Input Format: Component (SMPTE/EBU N10)
Video Format: 625i 25
Output: Component (SMPTE/EBU N10)
Composite Black Level 7.5 IRE
Control: Ref IN
FCP Easy Setup AJA Io La – PAL EBU N10 10 Bit Uncompressed
Thank you,
Any advice will be greatly appreciated.
Regards,
Tim
