IOHD Echo Issue
Javier Escobar
IOHD Echo Issue
on Feb 26, 2008 at 5:56:07 pm
Hey guys, I upgraded to newest AJA IoHD 5.1.1. It resolved my audio blackout issue. However now after editing for a couple of hours, I start getting this echo effect. It's like the audio repeats itself every half a second or so.
Only a system restart fixes it. A FCP update doesn't do the trick.
OSX 10.4.11
2x 3 GHZ Quad-Core Xeon
8GB 667 MHZ DDR2 RAM
Any hints?
Javier
Javier Escobar
Kevin Gardam
Re: IOHD Echo Issue
on Feb 27, 2008 at 12:35:35 pm
Hi Javier,
I'm having the same issues as yourself and I have the same spec as yourself. Aja support are aware of this as I contacted them yesterday.
I throw away fcp prefs and that sorts the issue but I don't know for how long.
Hopefully there will be an answer soon.I'll keep you posted
if theres a cure.
Kev
Kevin Gardam
Re: IOHD Echo Issue
on Feb 27, 2008 at 1:11:29 pm
A further point, I can create this echo fx by bringing up the sound prefs whilst in FCP or soundtrack. Closing the prefs
seems to clear the problem so it seems the sound prefs are corrupting or something. So if you bring up the prefs and close them down again, should keep pushing the problem away til aja
resolve it.
Kev
Forrest Burger
Re: IOHD Echo Issue
on Feb 27, 2008 at 4:30:38 pm
I've had this issue as well. What I do is click on another clip in the sequence that has audio, play that for a second, then go back to the clip that had the echo and it seems to stop.
Forrest
Kevin Gardam
Re: IOHD Echo Issue
on Feb 27, 2008 at 5:26:39 pm
Oh I wish my issue was as well behaved. Can take a bit of messing around to get rid off.
I look forward to what Aja make of it.
Paul Huppe
Re: IOHD Echo Issue
on Feb 28, 2008 at 8:49:21 pm
Javier, I've also ben having audio blackout issues and they're still unresolved.
How did you take care of the problem?
Paul
Tim Allison
Re: IOHD Echo Issue
on Feb 29, 2008 at 2:49:08 pm
Did you download and install the new AJA 5.1.1 software update? The old version was simply 5.1 software. When I put the new version on, I also had to update the firmware.
Kevin Gardam
Re: IOHD Echo - solved I think
on Mar 3, 2008 at 4:47:23 pm
If you select sound prefs-output and instead of having aja io
put internal speakers, this appears to stop the echo.
Not obvious I know as you would expect o/p to be iohd, so the iohd must be live regardless of o/p in sound prefs.
Hope this helps...and wasn't in the manual!
Javier Escobar
on Mar 3, 2008 at 8:29:56 pm
Today I have been Echo-free but hoping for a more stable fix.
THX, I'm glad to know I'm not the only one
Javier Escobar
Paul Huppe
on Mar 7, 2008 at 7:25:04 pm
I think I'm finally free of my audio blackout issue after updating to 5.1.1 (knock on wood)
WooHoo!
Paul
