Still trying to capture SD downconverting with IoHD
Alan Lacey
on Feb 15, 2008 at 6:20:39 pm
I'm trying to capture to SD (Pref 4:3) using the IoHD downconverting on the fly from a 1080i50 SDI ip.
The IoHD does the downconvert, I'm using 'crop' mode and the analogue output confirms this, but trying to capture (FCS2)with any of the 625 capture presets it just won't be having it.
I'd prefer SD ProRes(HQ) but any of the better quality codecs would do - this footage is for green screening.
Capture source is a PDW 350 which only has HD SDI op. Bit of a bummer as the new 355 does SD SDI as well.
Any ideas guys?
Thanks Alan
Jeremy Garchow
Re: Still trying to capture SD downconverting with IoHD
on Feb 16, 2008 at 3:13:41 am
First open your AJA control panel.
Set your primary format to 625i and your secondary format to 1080i50.
Open FCP. Choose an AJAioHD ProresHQ 625 setup.
You should be good there.
Jeremy
Alan Lacey
on Feb 18, 2008 at 11:55:20 am
Jeremy, you are a hero sir! It works flawlessly
It was having the secondary format needing to be 1080 that confused me. Also with 'down conversion' set to crop I can get 4:3 which is ideal for this project.
Thank you so much.
Alan
Jeremy Garchow
on Feb 18, 2008 at 3:26:21 pm
[Alan Lacey] "It was having the secondary format needing to be 1080 that confused me."
Yeah, it is a bit confusing as you'd think you would want it to be 625 as your primary should be 1080 cuz that's what you are feeing it. It's opposite from the downconvert.
Jerry Hofmann
on Feb 17, 2008 at 4:42:18 pm
I"d sure work natively if you can instead... especially if you're doing some compositing.
Jerry
Apple Certified Trainer
Author: "Jerry Hofmann on Final Cut Pro 4" Click here
Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
Jerry Hofmann
Something else...
on Feb 17, 2008 at 4:44:21 pm
ProRes HD isn't much larger a file than SD either... might transcode to that then composite, crop etc for the delivery. You'll get cleaner keys I'll wager.
Jerry
Alan Lacey
on Feb 18, 2008 at 12:02:25 pm
Thanks Jerry but we're a long way into this project and it's all SD so I think I'd prefer to stay that way for this.
I do take your point though!
Alan
