Black level NTSC setup
jose pantin
on Feb 13, 2008 at 4:14:04 am
I have always recorded with my camera (Sony Z1U) on 0 IRE NTSC setup (here we have the same system as in the US), but with a good amount of 100% zebra in every shot.
What setup should I use on the monitor (Sony PVM-14L2) connected to the AJA IO? Is the same if I connect it via s-video or via component?
For component the monitor has three options:
SMPTE 100/0/100, BETA 7.5 and Beta 0. Which one should I use?
Does the VTR (Sony DSR-45) have these same options?
Many thanks,
gary adcock
Re: Black level NTSC setup
on Feb 13, 2008 at 2:14:42 pm
[jose pantin] "What setup should I use on the monitor (Sony PVM-14L2) connected to the AJA IO? Is the same if I connect it via s-video or via component? "
none on the monitor.
Setup is only for analog NTSC signals - there is not setup over SDI.
Set your io to use the 7.5 IRE for analog out- the monitors should not be adjusted.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Inside look at the IoHD
jose pantin
on Feb 20, 2008 at 6:35:07 pm
Thank you so mucho
