IO HD with ProRes 422 HQ crashes FCP 6
Dave Martin
on Jan 30, 2008 at 8:16:37 pm
Hi Guys
It could be because my hard drives striped can only do 200 kbits per second and the files are 240 kbits per second but...Anybody else have this issue? It seems to work well with regular ProRes 422 but not HQ.
The render is coming out of After Effects CS3...thanks!
Dave Martin
- MacPro - MacBook Pro -
Jeremy Garchow
Re: IO HD with ProRes 422 HQ crashes FCP 6
on Jan 30, 2008 at 9:22:29 pm
What drive are you using that does 200kbits per second?
Dave Martin
on Jan 30, 2008 at 9:35:10 pm
I have three Hitachi Deskstars Striped Raid 0 internal on a MacPro. I'm pretty sure I get 200 kbits per second...
Dave Martin
Jeremy Garchow
on Jan 30, 2008 at 9:44:11 pm
You mean more like 200 MegaBytes per second. Plenty to do ProRes or HQ
So explain exactly what happens and what format, OS, QT, AJA drivers, version of everything you have ever owned, or more importantly what versions you are currently running.
Dave Martin
on Jan 31, 2008 at 4:27:15 pm
Well, the encode goes fine for ProRes 422 HQ out of After Effects and it plays well in Quicktime...but as soon as I drop it in a ProRes 422 HQ Timeline in FCP V 6.0 I get the spinning beachball.
I have the IO HD firmare 1.1 and Control Panel V 5.0 as well as Quicktime 7.3.1.
I thought about updating FCP but others have said it breaks more than it fixes...
Any ideas?
Thanks...
Dave Martin
Jeremy Garchow
on Jan 31, 2008 at 4:53:00 pm
FCP v6.0.2 is most stable version of FCP6 there is, in my experience anyway. Don't know if that's your issue though. I'd start there. Also, there's an update to AE CS3 to 8.0.2.
What resolution are you working in?
Jeremy
Dave Martin
on Jan 31, 2008 at 5:55:41 pm
Hi Jeremy
I guess I'll try the update (I'll clone first)
I'm working in 3500 x 1080 in AE and then stretching down to 1920 x 1080i for FCP
Thanks...
Dave Martin
gary adcock
on Jan 31, 2008 at 6:07:21 pm
[Dave Martin] "I'm working in 3500 x 1080 in AE and then stretching down to 1920 x 1080i for FCP "
The IoHD does not support video files larger than 1920 pixels wide at this time.
down convert in AE first.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Inside look at the IoHD
Dave Martin
on Jan 31, 2008 at 7:31:22 pm
Hi Gary
Yes...I made it 1920 x 1080 1 PreRes 422 HQ in AE and then tried to import...
Thanks...
Dave Martin
David Zimmern
on May 1, 2008 at 10:33:05 pm
I am running a macbook pro,7200rpm hd,4gig ram,fcp6,aja iohd,sata raid and have tried 800firewire graid.I get a kernal panic when I drop clip onto the timrline.It works fine for capturing.But when I do a time remap or play clip on a timeline" CRASH".A proApp Tec from Apple told me the system was not tested with an external raid!How do you test an edit system without an external drive?and OK the system.
thanks, dave Z.
gary adcock
on May 2, 2008 at 1:22:53 pm
[David Zimmern] ".A proApp Tec from Apple told me the system was not tested with an external raid!How do you test an edit system without an external drive?and OK the system"
an Apple store tech will not know anything about an IoHD so do not waste your time- if it is not sold in the store they will not know what it is or how to trouble shoot.
Since you did not tell us which OS and software versions start there,
did you update the Driver and THe IoHD
Have you called Aja's Tech support?
gary adcock
Studio37
Jeremy Garchow
on May 2, 2008 at 2:03:12 pm
[gary adcock] "Have you called Aja's Tech support? "
..and a kernel panic sounds like a bad system install. When' the last time you rebuilt your system?
David Zimmern
on May 2, 2008 at 2:29:15 pm
I am running os 10.5.2 fcp6 all up to date.system runs fine with just the raid connected,or just the aja iohd on my internal drive.It captures fine and plays fine from a clip but anything on the timeline is going to crash.
P.S.the iohd is updated on the firmware
thanks for the response,Dave Z.
