now I've seen it all
Bob Zelin
Re: now I've seen it all
on Jan 27, 2008 at 6:45:52 pm
I was wrong - I haven't seen it all -
http://www.markertek.com/Product.asp?cat=RACKSCASES&subcat=&prodclass=RACKA...
Arnie Schlissel
on Jan 28, 2008 at 6:10:50 pm
From Markertek: "This well designed, solution based breakout panel brings the connections of your IO HD to the front of your rack in one 2RU panel."
Because it would be so hard to simply turn the Io HD around in the rack to face the connectors out in the first place...
Arnie
Now in post: Peristroika, a film by Slava Tsukerman
http://www.arniepix.com/blog
Arnie Schlissel
Now it makes perfect sense!
on Jan 28, 2008 at 6:19:06 pm
I should have looked at your 2nd post before posting my ignorant reply above.
How could I have been so naive? So clueless? So dim?
You need to use these 2 rack mounts together. They're perfect companions. This way you can have both the connectors and the flashing lights facing out on the rack!
Arnie
Alan Lacey
Re: Now it makes perfect sense!
on Jan 29, 2008 at 6:44:21 pm
Shame you have to have the IoHD between them!
Alan
Arnie Schlissel
but wait, Bob, you forgot these!
on Jan 30, 2008 at 6:47:35 pm
The perfect companion, a rackmount for your iPod!
http://www.markertek.com/SearchProduct.asp?item=RXS%2DIRDS&off=24&sort=prod...
http://www.markertek.com/SearchProduct.asp?item=NUM%2DFITFORSOUND&off=13&so...
Arnie
