slight io problem
Rick Neely
slight io problem
on Jan 26, 2008 at 7:42:56 pm
Having a problem with an io,
running a dual 2.3 power pc mac with FCP 2 studio. We're having trouble with realtime previews on an external monitor. Settings are configured the best I think--
- IO is set on output settings (mirror on desktop enabled, same problem when disabled also)
- external video is set to all frames
- sequence is fully rendered
- have trashed preferences and rebooted, still no luck.
The monitor does display a freeze frame of the time marker point when the sequence isn't playing real time and when I drag the time marker the image DOES follow in the monitor. It just won't play sequences in real time.
Any suggestions would be great. Thanks!
Rick
gary adcock
Re: slight io problem
on Jan 26, 2008 at 7:55:49 pm
[Rick Neely] "The monitor does display a freeze frame of the time marker point when the sequence isn't playing real time and when I drag the time marker the image DOES follow in the monitor. It just won't play sequences in real time. "
then your timeline does not match your output.
reset the easy setup and try again,
do not let fcp choose the settings for the timeline- it can set it to frame sizes that do not output correctly
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Inside look at the IoHD
