IO doesn't seem to Uninstall
Dave Martin
on Jan 15, 2008 at 10:30:02 am
Hi Guys
So I'm trying to uninstall the IO drivers/prefs etc so I can install my new IO HD. I downloaded the uninstaller app and ran it. It said it worked but my presets were still listed in FCP. So I ran it again...it found three other files to delete. I rebooted and...the fcp presets are still there.
Is this normal? Has anyone else run into this?
Thanks...
Dave Martin
- MacPro - MacBook Pro -
gary adcock
Re: IO doesn't seem to Uninstall
on Jan 15, 2008 at 1:58:30 pm
[Dave Martin] "So I'm trying to uninstall the IO drivers/prefs etc so I can install my new IO HD. I downloaded the uninstaller app and ran it. It said it worked but my presets were still listed in FCP. So I ran it again...it found three other files to delete. I rebooted and...the fcp presets are still there. "
you are running the AJA un-installer that was with the older version of the software?
FCP prefs are not reset until the reinstall.....
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Inside look at the IoHD
Dave Martin
on Jan 15, 2008 at 4:18:45 pm
Thanks Gary
I downloaded the uninstaller straight from AJA.com. Sounds like this is normal and they'll be gone once I install the IOHD?
BTW-may I ask your procedure when you switch back and forth between IOHD and IO?
Thanks again Gary...
Dave Martin
gary adcock
on Jan 16, 2008 at 4:33:56 pm
[Dave Martin] "I downloaded the uninstaller straight from AJA.com"
all aja driver installs include an uninstaller, in the folder where the apps are stored. downloading a newer version will not remove all of the files- every version is different, that is why the files were no properly removed.
"sk your procedure when you switch back and forth between IOHD and IO? "
Switching between drivers.
I uninstall using the current drivers uninstaller
( found in Applications >AJA Utilities and I keep the icon in my dock for simplicity)
then run the installer for the replacement driver and reboot.
gary adcock
Studio37
