AJA IO ld
Mark Welch
AJA IO ld
on Jan 10, 2008 at 9:01:55 pm
Here's the config. I'm contemplating:
I'm getting a DVC Pro 50 camcorder with SDI out. I want to get that signal into my iMac that only has FW 400 & 800 inputs. No way to install a card on that computer. Of course, there is no deck control.
Will the AJA IO ld be sufficient to get that SDI signal into the Mac via firewire? What issues or problems will I be facing? I've been editing DVCAM for years so this work-flow is new to me.
Editing with FCP 6.
thanks
Bob Zelin
Re: AJA IO ld
on Jan 11, 2008 at 12:15:22 am
and what drive will you record on? You can't use a FW drive, since you are using the FW buss for the I/O LD.
Bob Zelin
Mark Welch
Re: AJA IO ld
on Jan 11, 2008 at 1:11:32 am
hmmm,
Right now I have an external FW drive I record media to (DV), so you're saying I need a SCSI or RAID drive. How would I integrate that into an iMac. I would assume that's not do-able.
thanks
Mark Welch
Re: AJA IO ld
on Jan 11, 2008 at 1:45:26 am
Well, I guess the solution would be to use a DVC Pro 50 deck with FW out and bypass the AJA altogether. No?
Bob Zelin
Re: AJA IO ld
on Jan 11, 2008 at 4:07:41 am
the solution is to not use an iMac for professional applications.
Bob Zelin
Mark Welch
Re: AJA IO ld
on Jan 11, 2008 at 1:00:35 pm
I hear ya - thanks.
gary adcock
Re: AJA IO ld
on Jan 11, 2008 at 3:33:31 pm
[Mark Welch] "How would I integrate that into an iMac. I would assume that's not do-able. "
The IoHD is not certified to run on an iMac since it does not allow for capture to bus secondary to the FW.
so no it will not work for you.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Inside look at the IoHD
