Capturing VHS via IO
LankBeach
on Dec 14, 2007 at 4:21:09 pm
When I am capturing video from vhs to FCP via the AJA io I run into trouble with dropped frames. I use the capture now feature in the log and capture window but it cancels itself when it detects a dropped frame.
However, when it doesn't get automatically cancelled when a drop frame occurs I get some weird beeps that are getting recorded in the audio.
Any way around these problems?
dean
Re: Capturing VHS via IO
by
on Dec 18, 2007 at 9:33:10 pm
If you have access to another firewire device, like a deck or a camera (with an av pass thru)you might try capturing without the IO.
