COLOR and Aja IO HD
xtrmn8ngangl
COLOR and Aja IO HD
on Dec 5, 2007 at 5:02:38 pm
Hallo,
hallo, i have read on a forum that when working with Color in HD the Aja IO HD cannot be used for external monitoring because it doesnot support Firewire in HD...is that true? is there any workaround for this ? i would appreciate any help...
JeremyG
Re: COLOR and Aja IO HD
on Dec 5, 2007 at 5:33:01 pm
SD only for the moment.
Jeremy
Arniepix
on Dec 5, 2007 at 9:00:53 pm
The workaround is to use an AJA Kona card.
Arnie
Now in post: Peristroika, a film by Slava Tsukerman
http://www.arniepix.com/blog
gary adcock
on Dec 5, 2007 at 11:06:40 pm
[xtrmn8ngangl] " i have read on a forum that when working with Color in HD the Aja IO HD cannot be used for external monitoring because it doesnot support Firewire in HD...is that true?"
The IoHD currently only supports an SD preview from HD sources when using Apple Color.
This is a limitation of the Color application and not the IoHD.
This is the ONLY FW preview that is available/ supported in Color.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Inside look at the IoHD
uncompressed
on Dec 6, 2007 at 7:59:36 am
Kona 3 always was the best working with FInal Touch, still so with FCS 2's color.
the graphic card is always the bottleneck with color, definitely look into a Desktop Kona 3 with ATI X1900 XT. you'll have serious coloring capabilities with that type of system, in fact the opposite of the experience of color on a laptop today.
Christopher Wright
on Dec 8, 2007 at 6:58:20 am
Also the Matrox MXO new beta driver also works with Color, SD or HD.
