HDMI In
lightshow
HDMI In
on Nov 3, 2007 at 4:42:58 am
Has anybody tried running a computer into the HDIO via the HDMI in at 1920 x 1080 60hz? I need to capture some software demos at a remote location, it would be slick if I could leave the Barco Image Pro HD at home.
gary adcock
Re: HDMI In
on Nov 3, 2007 at 11:39:00 pm
[lightshow] "as anybody tried running a computer into the HDIO via the HDMI in at 1920 x 1080 60hz? I need to capture some software demos at a remote location, it would be slick if I could leave the Barco Image Pro HD at home. "
It is my understanding that the IoHD conforms to the Video specs under the HDMI 1.2v specs
I know of no computer that can output a true video signal- nor do I know of any computers that use HDMI as an output.
While It may be possible to use a DVI- HDMI cable - most of the HDMI capable output devices ( plasmas for example) want a 25-35 hrz signal.
A Kona card set to Macintosh Desktop does this all day long, however.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
http://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
lightshow
Re: HDMI In
on Nov 5, 2007 at 10:38:21 pm
Thanks for the input Gary...
I've got a Kona system, unfortunately the Kona desktop out has no OpenGL graphics acceleration, so moving graphics are very jerky.
I use a lot of Gefen switchers and routers that have HDMI inputs, so I have tons of DVI to HDMI cables and all the demo systems here have HDMI adapters on them. I was hoping I could feed 1920x1080 at 59,94 or 60hz from the graphics workstation into the HDio with genlock to feed the HDio at remote locations and also into the HD switcher I use on live events.
I demoed the new Gefen DVI to HD-SDI scaler w/ genlock (EXT-DVI-2-HDSDISP), but it doesn't genlock reliably into my HD Switcher or into my Kona 3. They are sending a new unit, but I'm skeptical at this point.
The Barco Image Pro HD here doesn't look good at digital resolutions past 1600x1200, analog to HD-SDI is OK.
It looks like I'm going to spend bigger bucks on the Miranda dvi-ramp2, which many of the networks use when they want to capture high resolution DVI to HD-SDI signals. It's too bad because it doesn't do anything else, where as the HDio would give me tons of uses around here.
Mark
Brian Holmes
Re: HDMI In
on Jun 25, 2008 at 8:40:53 am
Hi Mark,
I was wondering if you tried the DVI to HDMI cable and had any success, or did you go down the converter route?
I need to capture some footage from a computer via the ioHD, so any tips you have would be great.
Thank you,
Brian
gary adcock
Re: HDMI In
on Jun 25, 2008 at 1:35:07 pm
[Brian Holmes] "I need to capture some footage from a computer via the ioHD,"
you cannot do that with an IoHD.
AJA devices will only accept SMPTE standard video signals- this is best done in Hardware using a device called a "1024" to convert computer display signal to actual Video.
or use a screen capture utility like camatasia or Snapz pro.
gary adcock
Studio37
Inside look at the IoHD
