ioHD and firewire VCR's
Jim Nicholls
on Oct 30, 2007 at 3:47:53 am
In a thread below a user commented that the ioHD effectively takes over all firewire ports native to the Mac Pro by dominating the bus. Bob Zelin helpfully suggested a firewire PCIe Card ( http://sonnettech.com/product/tangoexpress800.html ) to make more firewire ports available.
I am interested in the ioHD, but amoungst other analog decks use firewire VCRs (DSR 11, DSR 40 and HDV decks for ingest and output) that ostensively cannot be connected at the same time. This may be a deal killer for me. Does anyone have any idea if an accessory firewire card similar to the one above will allow simultaneous use of the ioHD and a firewire VCR deck with preview output to a monitor via the ioHD at the same time?
Jim
gary adcock
Re: ioHD and firewire VCR's
on Oct 30, 2007 at 3:59:00 am
yeah?
Any additional FW card will allow you to have the IoHD on one bus and your storage on another, that is the sole purpose of having the "dumb" storage is separated from a "smart" device
But remember that once you have the content on your computer you no longer need to have your decks connected over FW. Your output is now previewed via the IoHD.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Jim Nicholls
on Oct 30, 2007 at 4:36:59 am
Thanks Gary,
According to the Io HD manual on page 31 "if you want to use other firewire devices in addition to Io HD such as cameras and VTRs, for proper operation, you must only use one device at a time" further "If you finish using the (firewire) camera and want to use the Io HD, power down the system, power down and/or disconnect the camera, connect and/or power up the Io HD, then start the computer."
This is hardly a convenient work flow, so I would like to find out if it is possible to use a firewire deck at the same time with an accessory firwire card.
Jim
gary adcock
on Oct 30, 2007 at 12:52:31 pm
This is hardly a convenient work flow, so I would like to find out if it is possible to use a firewire deck at the same time with an accessory firewire card.
I doubt it - the IoHD uses the serial protocol over FW and delivers that serial control via the 9pin or LTC ports - having more than one device like that on your computer is not a good idea, as FCP is NOT smart enough to deal with 2 conflicting serial controls functions over the 2 different FW connections
Blame the FW protocols for the inconvenience, ALL devices that can control via serial over FW need take over the entire FW bus when working in SD and now in addition to the serial control we are also talking about the larger file sizes HD content, People are going to have to change how you work. ( see bob's tirade on using FW drives in this forum)
gary adcock
Studio37
Jim Nicholls
on Oct 30, 2007 at 1:41:19 pm
Thanks for that info Gary, disappointing but at least now we know.
Jim
Bob Zelin
on Oct 30, 2007 at 9:26:10 pm
Jim -
I can't understand why you would spend the $$$ on an AJA I/O HD, when it looks like you really don't need it. The I/O HD is for guys who are dealing with all this HD stuff, or HD projects that need upconversion to HD. You have a bunch of basic FW decks like the DSR-40 and DSR-11. Why spend the money - and if you do need to simply output to a Beta VTR (for example), just get a Kona LHe.
Bob Zelin
Jim Nicholls
on Nov 1, 2007 at 9:53:55 am
Thanks Bob,
I have come to the same conclusion after help from this site. I reckon the IoHD is better for people who want to use the ProRes codec with HD SDI decks. I was surprised to find that the ProRes codec has a minimum data rate some 10X greater than DV (and HDV). I am not at the ProRes level but still want to be "future proofed" so I reckon the DVCPro HD codec will do for me in the near future (when I need an intraframe codec) at 1/2 ProRes rates and have now decided to go for a BMD Multibridge Pro as it has more I/O's than the Kona card and can operate in both Windows and OSX on a Mac Pro (I've still got lots of Windows software). Further the Multibridge Pro runs from the PCIe bus so there will be no conflicts with any firewire gear (I hope!) And I don't need "portable" gear (which incidentally also requires a "portable" raid array via the expansion bus if you want ProRes on your laptop!)
Jim
