Best setup for audio with Aja IO
Peterd
on Oct 26, 2007 at 1:15:02 pm
SO I'm working with some audio sensitive material and am a little confused on the best way to deal with audio using the IO. I have both computer speakers and a set of a rolands hooked directly into the IO box. I'm monitoring via composite to a broadcast monitor.
Someone else was editing on this system without realizing the setup and used the computer speakers and syncing it to the broadcast monitor. This is obviously going ot be slightly out of sync. I was wondering if there's a concrete number of frames the sync would be off by so I can correct it. In the long term I should always trust the rolands and broadcast monitor for verifying sync right?
Also is there a way to tweak the playback in FCP's displays to match the broadcast monitor?
Warren
Re: Best setup for audio with Aja IO
on Oct 26, 2007 at 4:45:20 pm
I think you need to set the offset in FCP to 5 frames.
Warren
Warren Eig
O 310-470-0905
C 310-560-6245
email: warren@babyboompictures.com
website: http://www.babyboompictures.com
http://www.atomfilms.com/af/content/knitwits
http://www.atomfilms.com/film/family_xmas.jsp
germane
on Nov 11, 2007 at 5:07:58 pm
I think Warren is probably right. There should be a standard offset default in the frame offset preference. If you shift your audio back by that amount it should be back in sync.
This is from the AJA FAQ if this helps:
Q: What is the correct "Frame Offset" I should use in Final Cut Pro to adjust for latency through Io?
A: In order to compensate for the latency you need to change the Playback Frame Offset in Final Cut Pro HD ( System Settings > Playback Control > Frame Offset) to a value of
