audio problems
JOSHUA
audio problems
on Jul 5, 2007 at 5:02:39 am
HELLO EVERYONE!
I HAVE FINAL CUT STUDIO RUNNING ON A G5 QUAD WITH AN AJA IO LA.
HERE IS MY PROBLEM... THE AUDIO GOES OFF DURING PLAYBACK.
COMES ON AGAIN IF I STOP THE PLAY AND TURN ON/OFF THE CAPTURE TOOL.
I UPDATED THE AJA DRIVERS 3.0 BUT IT DRIVING ME NUTS.
GOT ANY IDEAS?
PLESASE HELP!
THANKS
Bob Zelin
Re: audio problems
on Jul 5, 2007 at 11:15:58 pm
1) stop using CAPS for every word.
2) go to EASY SETUPS, and select one - like Pro I/O Betacam 8 bit uncompressed. This will route your audio thru the I/O box, and not default to DV/Firewire DV/NTSC.
3) load the Pro I/O Control Panel from AJA, and test your VTR thru the Pro I/O control panel. This will insure you that you are getting audio thru your I/O LA box.
Bob Zelin
