FCP Render??
ccbcvideo
FCP Render??
on May 9, 2007 at 9:06:54 pm
Hey folks,
Running a Mac Pro with FCP 5 and AJA Io and I am all of a sudden getting four channels of audio instead of just 2 and I have to render everything until I can edit...what is going on any ideas??
Thanks in Advance..
Chris
JeremyG
Re: FCP Render??
on May 9, 2007 at 11:10:24 pm
In the log and capture window, click on the clip properties tab and choose your audio inputs there. You are needing to render because you have captured to a format that does not match your timeline. Adjust your timeline to fit your captured settings by hitting control-q to being up the easy setups. Choose the proper setup and away you go.
Jeremy
ccbcvideo
Re: FCP Render??
on May 10, 2007 at 6:21:46 pm
Great Thanks Jeremy in diving into those menus I saw that someone had changed the frame rate...fixed right away..
Chris
JeremyG
Re: FCP Render??
on May 11, 2007 at 3:06:46 am
Sweetness...good catch!
