not mirroring on desktop
Chris Holmes
on May 3, 2007 at 8:06:37 pm
I'm preparing to edit a new project, and would like to work with a larger frame size than OfflineRT provides. However, when I set up my clips to be PhotoJPEG 720x486 @ 40% and play them in the Viewer or Canvas, the output isn't mirrored on the desktop.
Sequence settings are the same as the clips. Everything plays out on the monitor fine, but it's simply not mirrored on the desktop.
Is there something I'm forgetting.
Dual 2 GHz G5
FCP STUDIO
AJA IO
The only big thing is that we're not capturing off tape, a video/audio/TC Burn tap off the camera was run to a DVD recorder, and I'm using these camera DVD's of the interviews as the offline material. It's alot faster to use MPEG StreamClip to batch in all the interviews, over 50 hrs, than to capture them.
thanks
Chris
