Does the Io LD/LA family manage to bypass the 2 channel limit of audio via Firewire?
betamac
on Apr 1, 2007 at 5:14:36 am
Hi there,
I want to capture 4 channels of audio via SDI into a MacBook Pro.
I had discounted Io as an option because, as I understand it, Final Cut can only capture 2 audio channels via firewire, and Io uses firewire.
But AJA literature seems to suggest you can do it. Can anyone give me a definitive answer one way or the other from their experience with the Io-s?
Thanks for any help.
szumlins
Re: Does the Io LD/LA family manage to bypass the 2 channel limit of audio via Firewire?
on Apr 2, 2007 at 12:08:32 am
Yup, the Io LA and Io support 4 channel analog audio.
-Mike
JeremyG
on Apr 2, 2007 at 3:36:14 pm
AS long as you have QT 7 and FCP 5.0 or above.
