aja la
Anthony C
aja la
on Feb 24, 2007 at 1:52:21 pm
I was wondering if I can use the LA component out to a Panasonic 37" plasma monitor for video playback.
Has anyone used this set-up on a Macbbok Pro?
If this can't work what would you use?
Chris
Re: aja la
on Feb 24, 2007 at 7:22:31 pm
The AJA IO LA has component out. So, you can feed it into any monitor that has a Component input.
Or composite or Y/C.
Bob Zelin
Re: aja la
on Feb 25, 2007 at 4:11:53 pm
yes, this works
bob zelin
Anthony C
Re: aja la
on Mar 4, 2007 at 3:07:44 pm
Hi Bob,
What monitor would you use for playback of DVCPRO HD?
Bob Zelin
Re: aja la
on Mar 5, 2007 at 1:59:42 am
Anthony -
you started this thread off by asking if you could use a 37" Panasonic monitor, and I said YES. So to answer your question again, YES, your choice would work, as would countless other monitors on the market.
Bob Zelin
thrillcat editorial
Re: aja la
on Mar 10, 2007 at 3:22:51 am
The IoLA will not play DVCProHD out. It is SD only. Before you buy a new monitor to view HD, you'll need to get a Kona card.
travis ballstadt
http://www.thrillcateditorial.com
