Aja LA & Kona 2 (Can they work together?)
Lawrence Roussarie
on Jan 25, 2007 at 12:33:43 am
Hello: I have a Kona 2 card and want to add the - Aja LA i/o for component video and analog audio.
Can I select the LA to output/input analog while as the same time outputting/inputing SD video from the Kona 2 card?
Any issues with this?
I'll take a link...
Larry Roussarie
JeremyG
Re: Aja LA & Kona 2 (Can they work together?)
on Jan 25, 2007 at 1:17:36 am
It's one or the other, not both for input. You can get yourself a full io, hook it up to the Kona2 via SDI and then use that as a video router of sorts for all kinds of output, input is only one source though, or you can hook the component out to your la and route the signal analog as well.
Jeremy
