MBP AJA IO working in Pal with DV material ugly green line
Time for tea
on Dec 12, 2006 at 12:26:42 am
Any of you guy's out there woring with a MBP and AJA io box in pal ?
I have had my set up since July and have had to work in uncompresed 8 bit SDi using my G-Tech GRad 500 drive.
no problems with droped frames, but a bit limited with 4.5 hours storage.
If I capture at any DV capture settingd I get a green line at the botom of the pic on the o/p from the io box.
not seen on the viewer or canvas, just on o/p.
I'ts only noticable on under scaned monitor, and is not there at all if I run in NTSC.
any ideas?
I had been discusing this with AJA suport back at the end of July, they did final agree there was a problem with the Io on the intell MBP in pal with Dv but have not yet come up with a solution.
It is very frustrating t be limited to 2 video streams when most of the time I would be happy to work in DVpro50 res
Steve
how about a nice cup of tea
