Io LA and FCP voice over tool
chrispy
on Oct 2, 2006 at 2:45:15 pm
I've got an Io LA which is working fine but when I open the Voice Over Tool and select the Pro IO as the input source, it reports that the device is being used. If I put External Video to Off, or Video Playback to None, it will then allow me to switch the input source to Pro IO but then I won't be able to send the video playback to the video monitor in the v/o booth when I play the timeline.
What I would like to do is to play the timeline and do a voice over recording using the Voice Over Tool.
Any advise ?
-chrispy
mactrix
Re: Io LA and FCP voice over tool
on Oct 4, 2006 at 12:19:02 pm
It doesn't work with the AJA Io. It's not a core audio device.
You need to use another audio input ...
