AJA KONA 3g VS DeckLink 4K Extreme 12G
Aboud Orfali
on Mar 11, 2015 at 11:56:36 am
Dear all;
I need your help by deciding between the AJA KONA 3G and the DeckLink 4K Extreme 12G.
Will any one try to provide a true comparison based on the capabilities , performance, problems , support ...etc .
Please your opinion is highly appreciated.
Thank you all
Aboud
Shane Ross
Re: AJA KONA 3g VS DeckLink 4K Extreme 12G
on Mar 20, 2015 at 1:43:48 am
For use on what NLE?
The main difference between them is the customer service and tech support. AJA's is world class, BMD's has a bad rep...tough getting a hold of representatives, and solutions not found after dealing with them. AJA's rep is well deserved.
How they perform depends on the NLE...I find AJA works best with Avid over BMD. BMD offers analog inputs for older hardware, where AJA does not, but both offer equal outputs.
Shane
Little Frog Post
Aboud Orfali
on Mar 22, 2015 at 1:10:54 pm
Dear Shane;
Thank you for your reply; as for the NLE used it is a 4K workflow with the new 8-cores Mac Pro (Final Cut Pro x / 4:4:4:4 codec ).
Thank you for all the help and support .
