Kona 3 and Premiere Pro output
Naveen Mallikarjuna
on Nov 5, 2013 at 8:37:13 pm
I'm running Premiere Pro CC 7.1.0 (141) on my Mac Pro OS X 10.7.5 with an AJA Kona 3. Kona drivers are 10.4.7.
When I play a clip in Premiere, the video plays out of the Kona fine to an external monitor. The problem is with the audio, which "pops" a lot, or cuts out altogether.
Anybody have a suggestion on how to fix this? Does 10.4.8 for the Kona drivers help, or is that just an update to work with OS X 10.9?
Naveen
Naveen Mallikarjuna
Re: Kona 3 and Premiere Pro output
on Nov 13, 2013 at 7:52:25 pm
I called AJA support. Forgot how good it is and that they take care things fast. Here was their solution, which worked perfectly:
Audio Setting in Premiere Pro CC for Kona 3:
1. Go to Premiere Pro > Preferences > Audio Hardware
Use the following settings:
Adobe Desktop Audio: Built-in Output
Buffersize: 1024
Map Output for: AJA Kona 3 - 0, Slot 3
2. Go to Premiere Pro > Preferences > Playback
Audio Device: AJA Kona 3 - 0, Slot 3
Then, change the audio settings on the Mac
1. Go to Mac OS X Preferences > Sound
For both Output and Input, choose any device EXCEPT AJA Kona 3 (yes, counter intuitive)
That's it.
Naveen
Michael Lansdell
on Jun 2, 2014 at 7:53:16 am
Have you played out to tape from Premiere Pro CC using a Kona 3? I've a tight deadline project in it very soon and usually work in FCP/Symphony... Would be good to get a heads up on any potential issues!
Best wishes,
Michael
