wrong output-Premiere Pro
Greg Jones
on Aug 6, 2013 at 4:08:22 pm
I'm using Premiere Pro with the 10.4.5 Drivers from Aja. I just noticed today that in Premiere my stereo output is reversed. Both in the analogue monitoring and sdi output. My left channel is going out the right channel and vice-versa. In Final Cut Pro 7 it works fine, but when I switch to Premiere its reversed. The meters show up correctly in Premiere, but the output is wrong. Anyone else experience this?
Greg Jones
D7,Inc.
Greg Jones
Re: wrong output-Premiere Pro
on Aug 10, 2013 at 2:06:18 am
Well I solved the problem. Apparently under the audio settings I somehow managed to switch the output of Channel 1 and Channel 2. I'm not sure how I did this because I wasn't even aware you could do this, but to fix it I dragged the left and right speaker icons under the Kona3G audio output and swapped them and it fixed it.
Greg Jones
D7,Inc.
