Switching between Premiere Pro and After Effects with an IOxt or Kona3
Kris Merkel
on May 16, 2013 at 1:32:09 pm
This topic came up in the Premiere Pro forum and I am experiencing the same behavior with my IOxt. When working with Premiere Pro, the AJA control panel indicates that it is in use by PremierePro but when I switch to After effects the IOxt does not follow the app and continues to be in use by Premiere Pro instead of following the switch to AE. The only way I can force the Control Panel to switch to AE is to quit PrPro.
I think I remember this working at one point in time but it does not now. Both the PrPro sequence and the AE comp are the same frame rate and resolution.
Anyone have any ideas on how to force the control panel to follow the active application?
"Think of everything in terms of building capacity."
Kris Merkel
twitter: @kris_merkel
Product Manager, Flanders Scientific Inc.
http://www.shopfsi.com
Co-Founder, Atlanta Cutters Post Production User Group
http://www.atlantacutters.com
2.2Ghz MBP core i7
16Gb RAM
CS6/FCP7
AJA T-Tap
AJA IO XT
FSI LM-2461W/CM-170W
Matthew Sonnenfeld
Re: Switching between Premiere Pro and After Effects with an IOxt or Kona3
on Jun 7, 2013 at 4:39:20 pm
It sounds to me like a Mercury Transmit issue. I don't actually think that AE supports Mercury Transmit like Premiere, Prelude, and Encore do. These applications will automatically follow you when you switch between them but I don't think AE does. I could be wrong but I couldn't find anything about AE actually having this support.
Blackmagic Cinema Camera, RED Scarlet-X, Panasonic HPX170, Canon 7D
2011 Macbook Pro 17", 2.3 Ghz Quad Core, 16GB RAM
AJA IoXT
Adobe Production Premium CS6, Avid Symphony 6, Final Cut Pro Studio 3
The College of William and Mary
