Proper way to capture 29.97 HD to 23.98p or 24P with Kona 3G
VIEW ALL   •   PRINT   •   NEXT >>
Chris Borjis
on Jul 21, 2014 at 5:42:20 pm
long story short, I need to play out from a black magic decklink
as HD 1080i 29.97, then capture that in another room to a Kona 3g
as 1080P 23.98 or 24. (over hd-sdi)
is that even do-able? I keep getting a split screen with
a double image top and bottom when configuring the kona 3g
from its control panel. And my broadcast monitor is freaking
out instead of showing a stable image and indicating 48hz mode, (24 frame)
which it is capable of (sony pvm-20/L5)
Chris Borjis
Re: Proper way to capture 29.97 HD to 23.98p or 24P with Kona 3G
on Jul 21, 2014 at 6:55:06 pm
disregard/never mind.
I just dropped it in a 24P premiere cc sequence and it plays back perfect.
Chris Borjis
on Aug 1, 2014 at 5:39:56 pm
update:
Thought it was good but the Kona3G doesn't do reverse pull-down,
so it had to be ran through a Teranex.
