Kona 3 AES input does not work
Naveen Mallikarjuna
on Mar 19, 2013 at 5:47:26 pm
Hi. I have a Kona 3 and don't seem to be able to get AES audio into my system. (First time trying)
Here's the set-up. I have a Audio-Technica AT2020 condenser mic hooked up to a Mackie 1402 mixer (provides phantom power). I'm going out of the mixer into the Kona 3 breakout box (Ch 1/2 in).
I don't see any audio input levels in Soundtrack Pro or the System Preferences Sound panel. (In both, Audio Input is set to AJA Kona 3.)
If I go out of the mixer and into a speaker (instead of the BOB) then I get audio. So the speaker/mixer/output is working fine. It's just going into the BOB where I lose audio.
In the AJA Control Panel, I have the Audio Input set to AES/EBU (xlr).
Is there anything else I can try?
Naveen
Naveen
Naveen Mallikarjuna
Re: Kona 3 AES input does not work
on Mar 19, 2013 at 8:58:38 pm
OK, so the obvious answer (and most likely the problem) was that I am using an analog xlr cable to go into the Kona 3 BOB, which is of course AES/EBU digital.
So, the question is: can I just buy an AES/EBU xlr cable and will that work with my analog mixer? Or is there some kind of convertor I need?
Naveen
wolfgang schabhuettl
on Mar 20, 2013 at 11:14:47 am
you need a AES > analog converter like the ada4
http://www.aja.com/en/products/mini-converters/ada4/#overview
Naveen Mallikarjuna
on Mar 21, 2013 at 8:39:48 pm
But...can I use something like this?
http://www.bhphotovideo.com/c/product/748788-REG/Sescom_SES_AES_EBU_1_110_O...
It's so much cheaper it makes me think there must be some reason why I cannot...
Naveen
John Pale
on Mar 22, 2013 at 5:01:42 pm
No. That's not an analog to digital converter.
It just is an adapter between Two types of AES audio connections (BNC and XLR).
Naveen Mallikarjuna
on Mar 22, 2013 at 5:51:05 pm
OK, thanks for the info.
Naveen
