Getting FCPX playback through LHe+ and out to Monitor
Barry O'Brien
on Dec 6, 2012 at 8:06:21 pm
Thank you in advance for your help.
I have a question that might be simple. I can't see the output of FCP X on my monitor which is getting it's signal from my Kona LHe+ AJA video board. I am brand new to FCPX, so I may be making a basic mistake.
I am seeing bars, which the AJA board is generating.
It works fine in FCP 7 - the signal comes in on the monitor on the RBG input.
Under FCP X Preferences>Playback>A/V output it says "none found." There are no other choices. Under Windows, A/V Output is greyed out.
Barry
Barry O'Brien
Re: Getting FCPX playback through LHe+ and out to Monitor
on Dec 7, 2012 at 10:01:04 pm
I'll answer my own question. Dawn at AJA support was both very responsive and very helpful.
For OS 10.6 and FCP 7, I needed the 10.1 Kona Driver, which I had.
For OS 10.7.6 and FCP X [10.0.6]I needed to load the 10.4.2 Kona Driver. Once I did that, and made sure that the A/V output of FCP X was checked, all was good.
Barry
