SDI Outputs no signal
Lars Larson
on Aug 13, 2012 at 10:26:51 pm
Hello,
I've been using the Kona 3 into a Panasonic BT-LH1700WP to better monitor my editing sessions. But now, for some reason, the SDI output I had been using isn't registering any output.
The inputs on the monitor itself are fine: they work when attached directly to my camera. Also, Final Cut Pro is recognizing that the Kona card is active.
Thoughts? Help?
Thank you
gary adcock
Re: SDI Outputs no signal
on Aug 13, 2012 at 11:46:54 pm
[Lars Larson] " But now, for some reason, the SDI output I had been using isn't registering any output."
you do not mention what formats and frame rates.
Are you sure that your input source is correct on the montior?
shut off FCP open the Aja control Panel ONLY
Turn on Bars if they are not on already.
Still No signal?
Call tech support.
gary adcock
Studio37
Post and Production Workflow Consultant
Production and Post Stereographer
Chicago, IL
http://blogs.creativecow.net/24640
follow me on Twitter
@garyadcock
Shane Ross
on Aug 14, 2012 at 4:14:18 am
Card might need to be reseated too. If you are brave enough to open the machine and do that. If you didn't install it, I'd have the person who did do this, or let tech support walk you through this.
Shane
Little Frog Post
