Upconvert SD Letterbox to HD
Tom Dempsey
on Aug 6, 2012 at 1:33:07 am
Hi, does anyone know if Kona has a way of upconverting letterboxed SD footage to full raster HD?
Possible workflow?
td
tom dempsey
Doug Beal
Re: Upconvert SD Letterbox to HD
on Aug 6, 2012 at 3:06:24 pm
select Zoom letterbox in the control panel for upconvert, select what you want to end up with in fcp easy setup, select the format you are coming from in the secondary format in the Kona control Panel.
Capture the footage. it will be a little softer than if the SD footage was anamorphic
Doug Beal
Editor / Engineer
Rock Creative Images
Nashville TN
Tom Dempsey
on Aug 6, 2012 at 4:50:52 pm
excellent. thank you, i will try that.
td
tom dempsey
