Kona LHe Stereoscopic capture
Tom Bell
on Jul 23, 2012 at 4:51:30 pm
Can someone tell me if I can capture a "dual stream" 3D sdi signal, output from an SRW 5800 on my LHe capture card?
Tom.
Mark Spano
Re: Kona LHe Stereoscopic capture
on Jul 23, 2012 at 5:44:15 pm
I don't think you can capture multiple streams at once with LHe. It has one SDI input. However, you should be able to capture them separately. The deck should have a feature in its VTR Setup menu to choose which stream will play out the standard 1.5G HD-SDI port. Set to Stream A, capture, switch to stream B, capture again. You'll have separate L and R files, which most 3D post pros know how to work with.
Gunter Hemeleers
on Jul 24, 2012 at 12:40:06 pm
The Kona3G will be able to do it.
Hemeleers Gunter
Mac Pro, Imac 24", Macbook Pro 15" all intel
