Can't hear Audio on HDMI TV from Kona Lhi using Premiere Pro 5.5?
Chris Holland
on Apr 26, 2012 at 5:53:34 pm
HI. I was hoping someone might have the solution to this problem.
I can't hear audio out to my Vizeo TV that I am running the HDMI cable to from the AJA Kona Breakout Box.
It works fine in Final Cut. i have tried messing with some settings to get it out to the TV in Premiere but intoning has worked. I can hear audio in my system speakers that are running out of my board.
It is an Lhi card using update 10.1.
The Audio Hardware and Audio Output Mapping are set to Bult In Line Input/Built in Line Output.
I have tried a few other settings and none seem to play the audio on the HDMI Output
If anyone has any suggestions please let me know. Thanks
Chris Holland
Editor/Animator
Chris Holland
Update
on Apr 26, 2012 at 6:03:05 pm
Update:
I should have checked this before but it seems the problem is only with an SD Timeline. The SD project will show the video but it won't play the audio.
Thanks.
Chris Holland
Editor/Animator
