Kona 3 Video Playback for DV
Ed Kulzer
on Apr 21, 2012 at 4:45:56 am
Evening COW--- Looking to tap some knowledge.
12-Core Mac Pro ( 2 x 2.93 GHz) wi/ 128GB RAM
I'm running FCP 7.0.3 with the AJA Kona 3 & BOB, monitoring with the Flanders LM-2461W.
The Kona Video Playback settings all seem to be 720 x 486; D1---- while the client's footage & sequence are 720 x 480; DV.
When I port the sequence over to Color for the grade, the sequence & material play just fine on the Flanders monitor--- but in the FCP timeline, no dice. No Video playback.
Any suggestions on what the proper A/V Settings & Video Playback should be?
I've had the sequence set to
720 x 480 NTSC DV (3:2)
NTSC - CCIR 601
29.97
Apple ProRes (HQ)
The AJA Kona Control Panel's set to 525i for Primary & Secondary and it's an SDI feed, which, again, works just fine with this material when inside of Color. Just not within FCP.
Am I missing a Kona Easy Setup?
Thanks in advance.
Doug Beal
Re: Kona 3 Video Playback for DV
on Apr 23, 2012 at 3:02:55 pm
set easy setup to AJA Kona3 NTSC 8bit to DV
Doug Beal
Editor / Engineer
Rock Creative Images
Nashville TN
David Cabestany
on Apr 24, 2012 at 9:11:36 pm
Sorry for deviating from the original question, but I thought Mac Pros could only take 96gb when running Mac OS? How did you manage to have the system see the whole 128gb?
