theoretically and practically question
Ismet Arnautalic
on Dec 18, 2011 at 1:51:39 pm
Is it possible to convert SD video from 4:3 to SD 16:9 without squeezing pictures? (loosing part of pictures on top and bottom)
If it possible, how to do it with Kona 3
If it is not possible:
Can I decide which part of picture I must loose. I prefer bottom part.
Any help
Regards
Shane Ross
Re: theoretically and practically question
on Dec 19, 2011 at 7:51:01 am
[Ismet Arnautalic] "Is it possible to convert SD video from 4:3 to SD 16:9 without squeezing pictures? (loosing part of pictures on top and bottom)"
Not really. How can you take the 4:3 space...and make it 16:9 without stretching it...or cutting off the top and the bottom? How can you do that? Make a square into a rectangle without changing it's shape?
[Ismet Arnautalic] "If it is not possible:
Can I decide which part of picture I must loose. I prefer bottom part."
You'd have to capture as Pillarbox, and then manually blow up the picture the last 33%, and pan and scan it.
Shane
Little Frog Post
Ismet Arnautalic
on Dec 19, 2011 at 1:12:17 pm
Thank you Shane very much. Now it is much clear for me. I think computer can make everything.
Regards
