Aja kona lhi and Adobe Premiere 5.5
Rainer Wirth
on Sep 5, 2011 at 8:36:48 pm
I can't get monitoring with Kona lhi in Premiere 5.5.
I'll get sound, yes, but no picture.
Any idea?
thanks
Rainer
Danny Nieder
Re: Aja kona lhi and Adobe Premiere 5.5
on Sep 5, 2011 at 11:05:45 pm
Without more details from you, it could be many things. I also have the LHi card and CS 5.5 and have it working pretty well.
Did you use an AJA sequence preset? Are you getting video monitoring in the preview window and not the timeline? Have you checked your cables, connections, etc? Are you using the AJA player and not the Adobe Player in the playback settings? (Look in the preferences, and also you can right click and set the playback settings in the program monitor.)
I have found AJA tech support to be great- try them as well.
Good luck.
walter biscardi
on Sep 5, 2011 at 11:24:43 pm
You must us an AJA Sequence Preset to get video output.
Walter Biscardi, Jr.
Editor, Colorist, Director, Writer, Consultant, Author, Chef.
HD Post and Production
Biscardi Creative Media
Blog Twitter Facebook
Rainer Wirth
on Sep 7, 2011 at 11:15:28 am
Hi Walter,
I don't get any Aja presets in the preferences of Premiere Pro. i just get the premiere settings. I've installed aja software and firmware. Where are the aja sequence setings?
Rainer
Tom Daigon
on Sep 7, 2011 at 2:35:01 pm
On the "New Sequence" screen (File/New/Sequence), under "Available Presets" you will find what you are looking for.. At the very top of this list is the AJA folder. Inside are a variety of sequences presets that you can select from.Choose the one that matches your majority of source clips.
Tom Daigon
Avid DS / PrP / After Effects Editor
http://www.hdshotsandcuts.com
Mac Pro 3,1
8 core
10.6.8
Nvidia Quadro 4000
24 gigs ram
Maxx Digita / Areca 8tb. raid
Danny Nieder
on Sep 7, 2011 at 6:41:14 pm
Did you install the AJA Premiere CS5.5 plugin as well as the AJA driver? Maybe that is why you aren't seeing the AJA sequences in Premiere. Check the driver download page - you need both to run smoothly.
walter biscardi
on Sep 7, 2011 at 10:43:58 pm
[Rainer Wirth] "I don't get any Aja presets in the preferences of Premiere Pro. i just get the premiere settings. I've installed aja software and firmware. Where are the aja sequence setings?"
You have to download the AJA Premiere Pro plug-in package. It's on the same support page where you download the AJA Drivers.
Gary Griffeth
on Nov 15, 2011 at 5:59:02 am
What if you want toedit a SD 24p project and have it display on the Lhi output? Have you found a way to do that?
