Kona LHi SDI to Panasonic Monitor SDI horizontal shift?
Jaeson Koszarsky
on Aug 23, 2011 at 3:15:37 pm
We upgraded out Media100 edit systems to Suite2. We're using MacPros 2x6core with OSX 10.6.7 & 12GB RAM.
We just got our kona lhi boards installed. I updated to 9.0.3 from aja, did the corresponding firmware update.
I'm running the SDI out of the kona card to the SDI in on my panasonic monitor. I've got the test pattern appearing when I use the AJA control app and video out from the Media100 when I switch to that.
The problem is the video on the monitor exhibits a huge horizontal shift to the right. When I view the test pattern, the white bar is pretty much centered on the screen. Same thing when I view Media100 output.
Any suggestions?
Jaeson
Jaeson Koszarsky
Re: Kona LHi SDI to Panasonic Monitor SDI horizontal shift?
on Aug 23, 2011 at 3:59:20 pm
BTW, my panasonic monitor is model: bt-lh1700wp
Jaeson Koszarsky
on Aug 23, 2011 at 8:32:52 pm
Not sure what caused the problem but it went away after power-cycling the monitor.
Jaeson
