Kona 3 output to monitor in Premiere Pro 5.5
Erich Hoberg
on Jun 28, 2011 at 3:22:03 pm
I am investigating potential use of Premiere Pro with as much of my Final Cut Pro infrastructure as possible. This requires getting my Kona 3 to play nicely with CS 5.5. AJA did release an updated sequence "plug in" package enabling proper capture sequence preset and potentially output to tape through the Kona; however, Im not having any luck getting the signal out via sdi to the external monitor, except oddly enough when I'm inside the titler tool. Am I missing a setting somewhere either in the Kona config or Premiere Pro? Is it possible the issue is my non mercury engine optimized video card? I do know the signal is processed correctly to the monitor from AE in CS 5.5 which tells me this might be more Premiere related, but thanks in advance for any and all help.
Erich Hoberg
Thomas Pohl
Re: Kona 3 output to monitor in Premiere Pro 5.5
on Jul 11, 2011 at 10:41:31 am
The same happens to me. I tried the last driver 9.01 but just After FX sends the signal out.
Cheers
Thomas.
http://www.footage-online.de - RED footage and more available in HD, SD and RED RAW R3D
Thomas Pohl
on Jul 11, 2011 at 10:59:51 am
Sometimes the answer is not too far away:
http://blogs.creativecow.net/blog/5199/transitioning-part-3-aja-kona-boards...
Thomas.
http://www.footage-online.com - RED footage and more available in HD, SD and RED RAW R3D
