out of sync LHi
Jim Curtis
out of sync LHi
on Jun 6, 2011 at 8:43:39 pm
I'm having a hard time figuring this out. My A and V get out of sync, and stay 4-6 frames out of sync on this 25 min. short I'm cutting. Not sure what to blame. I have the latest AJA driver, super-fast RAID, all ProRes 422 footage, sequence all rendered, Unlimited RT on, etc.
If I export a QT movie, and play it in AJA TV, it plays in sync. Just not in FCP.
If I Refresh A/V Devices, it helps for about ten seconds, then it shortly drifts out of sync again.
Is there an offset setting in FCP to adjust for video delay? There's a setting in System Preferences > Playback Control > Frame Offset. But, it doesn't appear to do anything. I can set it to 0 or 30, and I get the same response out of the LHi.
Any ideas?
Jim Curtis
Jim Curtis
jamesphilipcurtis.com
MacPro (Harpertown-Early 2008) 2x4 3GHz; 32G RAM all the same brand; 10.6.3; QT 7.6.6; FCS3; Kona LHi in PCI slot 3 (8.1.1); Primary display: 30" ACD; Monitoring: Kona LHi SDI to AJA HDP2 converter to HDMI on the HP DreamColor.
Chad Tingle
Re: out of sync LHi
on Jun 8, 2011 at 3:59:38 pm
[Jim Curtis] "s there an offset setting in FCP to adjust for video delay? There's a setting in System Preferences > Playback Control > Frame Offset. But, it doesn't appear to do anything. I can set it to 0 or 30, and I get the same response out of the LHi."
Go into system settings... Playback control and you will find the frame offset.
Chad Tingle
Producer/Editor
