Which Kona are you?
Alex Gerulaitis
Which Kona are you?
on May 12, 2011 at 12:42:40 am
A client brought in a G5 with 10.4, and a Kona card to install in it. How do I figure out which Kona is it? I know it's either LHe or LSe (they look identical) - but which one?
TIA!
Alex (DV411)
gary adcock
Re: Which Kona are you?
on May 12, 2011 at 3:28:20 am
it should be marked on the card at the serial number.
if not doesnt cutter stevens still work there? he would know.
ga
gary adcock
Studio37
Post and Production Workflow Consultant
Production and Post Stereographer
Chicago, IL
http://blogs.creativecow.net/24640
Alex Gerulaitis
on May 12, 2011 at 3:43:34 am
Serial markings (back of the card):
AJA Video G 57712
VSC 00294484
On the PCB surface, lower right corner: 102035-01.
Does it tell you anything?
[gary adcock] "if not doesnt cutter stevens still work there? he would know. "
That's very, very helpful Gary! :) But for the record, he doesn't.
Alex (DV411)
Alex Gerulaitis
on May 12, 2011 at 4:18:39 am
The AJA TV app does display HD modes (720 and 1080 variants) along with SD modes, in "Display" menu - as does AJA QTToDPXTranslator. Does it mean with absolute certainty that it's an LHe?
The G5 doesn't have an FCP and I don't want to install it. Is there any other way to test the basic functionality of the card?
Again, TIA.
Alex (DV411)
Jean-Christophe Boulay
on May 12, 2011 at 3:21:46 pm
Is the AJA Control Panel installed on the system? In there, under the Info tab, you have the Hardware ID which should answer the question.
JC Boulay
Technical Director
Audio Z
Montreal, Canada
http://www.audioz.com
Alex Gerulaitis
on May 12, 2011 at 8:19:13 pm
Bingo, that's what was missing in the installation. Thanks JC, that did it. It's an LHe.
Alex (DV411)
