Can Aja Kona lhe works with Samsung monitor?
Bim Ajadi
on Apr 12, 2011 at 12:46:48 am
Hi
I'm wondering if the AJA Kona Lhe card works with Samsung monitor that i'm using- SyncMaster P2270HD? I have the leads that comes with Kona-LHe Standard AV Breakout cable but noticed there's no suitable connection with the cable to the monitor? Would I need to get adaptor?
Any advice here would be most appreciated as I've got the capture card with a Breakout Box and mac pro 8 core 2x2.4Ghz Quad-Core Intel.
Bim
Fred Connors Jr.
Re: Problem Solving 101
on Apr 12, 2011 at 1:00:55 pm
What are the input options of the SyncMaster P2270HD?
What are the outputs options of the Kona-LHe
Now if you have a match your ready to go.
If you don't have a match then you will need to find some kind of converter.
AJA makes all kinds of HD-SDI to XXZZY converter.
The Troupe - Modern Media Design & Production
Bim Ajadi
on Apr 18, 2011 at 3:19:14 pm
Hi
Sorry for late respond...
Monitor input -
Signal Input
Video SignalAnalog RGB, DVI, HDMI, Component , SCART, TV (Digital TV / Analog TV)
Sync. SignalSeparate H / V, Composite
ConnectorD - sub, DVI - D, HDMI, Component, SCART, DTV Tuner, Optical Out, Audio In, Headphone Out, CI - Slot
AJA ouput -
Digital:
SD and HD-SDI, SMPTE-259/292/296
Analog:
Composite/S-Video (Y/C):
NTSC, NTSCJ, PAL
12-bit D/A, 8x oversampling
SD Component:
SMPTE/EBU N10, Betacam 525 line, Betacam 525J, RGB
HD Component:
YPbPr, RGB
12-bit D/A, 2x oversampling
So what sort of converter do i need to go with Samsung monitor?
Is there online video tutorial to demonstrate how to install Aja card as I'm anxious i get it wrong??
Cheers again
Bim
Fred Connors Jr.
on Apr 19, 2011 at 1:08:48 pm
I would suggest an SDI to HDMI converter
http://www.aja.com/products/converters/
Gerry Lawson
on Apr 26, 2011 at 6:54:56 pm
Hi Bim,
It seems to me that all you would need are 3 BNC to RCA adapters.
The breakout cable from the Kona LHE has 3 BNC Male connectors for component output. Your monitor will have 3 RCA female connectors for the component input. The breakout cable may not be long enough to reach your monitor.
You probably need 3 BNC(Female) to RCA(Female) adapters. The link is just an example - I've never ordered from them.
http://www.pacificcable.com/Picture_Page.asp?DataName=RFA-8391
Then any component RCA patch cable to connect to your monitor.
http://www.pacificcable.com/Picture_Page.asp?DataName=254-506X
Good luck,
gerry
Bim Ajadi
on Apr 26, 2011 at 10:42:04 pm
Hi Gary
Many thanks for this. Does that mean I wont need to buy the AJA Video Hi5 HD-SDI/SDI To HDMI Video & Audio Converter?
Cheers again
Bim
