KONA3G - Test Pattern image problem
Andres Delgado
on Apr 6, 2011 at 9:58:25 pm
Hello friends of creative cow, I hope all is well, i create this post because I did not find solution, so, i have Kona3G and K-Box installed on a Mac Pro Quad Core... Let me explain my problem...
Yesterday I put a picture on the test pattern. When i load the picture looked good, but when I left the AJA ControlPanel, this image looked bad, first i load an .jpeg image, give me the error, and then i try with an .psd image and both look bad! What's wrong? I put a Ramp, Black or Multiburst and i dont have problem, look good without problem...
I have a question also, the Test Pattern is just to put a images of references and view it at the time to calibrate or something like that... im trying use this image with Test Pattern for when i go to any application that not use the aja kona: (Finder), the company's logo displayed on the TV screen...
My video output is by HDMI output to HDMI input of TV, i dont have problem with FCP is just with the Test Pattern and my Video Monitor Out is connected to a Betacam SP Sony UVW-1400, this connection to the Betacam can influence in this problem in the Test Pattern?
GOOD IMAGE - When i load the image in Test Pattern
BAD IMAGE - After load the image
CLOSE
Well I hope somebody can help me! Regards...
AJA Sales Department
Re: KONA3G - Test Pattern image problem
on Apr 7, 2011 at 12:55:24 pm
Perhaps the image you have created does not meet the criteria for what is appropriate for the Control Panel application; size, color, endian type, etc.
Please contact AJA Technical Support via phone or email for assistance.
AJA Video Systems
+1 (530) 274-2048 Intl.
(800) 251-4224 US
sales@aja.com
Chris Petri
on Apr 11, 2013 at 7:24:40 pm
Andres, you ever figure out what the problem was with your image? I am having a similar problem but not getting much help from AJA on it…
Andres Delgado
on Apr 13, 2013 at 2:15:21 am
Hi Chris, in my case the problem was in the old version of AJA Control Panel, they update the version and the problem was solved!!
Regards!
