Kona 3 and IO Express?
Larry Asbell
on Mar 15, 2011 at 10:07:52 pm
Do we yet know whether these can coexist in one Mac Pro running 10.6?:
One Kona 3 used by Final Cut Pro 7, and
One IO Express PCIe used by Avid Media Composer 5.5
Would there be two instances of the AJA Control Panel?
Larry Asbell
Re: Kona 3 and IO Express?
on Mar 16, 2011 at 2:54:28 pm
Greg Huson writes:
I checked with AJA.
Yes, they work fine together - we have it set up that way. Latest drivers, etc.
There's a little pulldown window in the upper left side of the control panel
that allows you to switch between devices. In FCP, you just use the easy setup
that's correct for the device. In Avid, well, only the IO Express works.
gh
Greg Huson
Secret Headquarters, Inc
Post Production / Production
Culver City, CA
323 677 2092
323 677 2096 F
http://www.DigitalServiceStation.com
greg (at) SecretHQ.com
http://www.SecretHQ.com
Doug Beal
on Mar 16, 2011 at 4:09:38 pm
You should consider making this box dual boot. Boot into Avid or boot into FCP.
There is a time when all will be well with the same QT and OS then there won't.
FCP usually will accept updates before Avid, though in some cases updates will break it as well.
Doug Beal
Editor / Engineer
Rock Creative Images
Nashville TN
Jeremy Garchow
on Mar 16, 2011 at 4:29:55 pm
[Doug Beal] "You should consider making this box dual boot. Boot into Avid or boot into FCP."
Agreed. Don't run Avid and Fcp in same boot drive.
That being said, you can have more than one AJA device installed on the FCP partition and be totally fine.
Jeremy
Larry Asbell
on Mar 16, 2011 at 5:41:35 pm
I know that I "shouldn't" but . . .
I've been using MC and FCP on the same partition for about three years. In fact plenty of times I've run both programs simultaneously in order to check or pull info from earlier sequences. No problem. I even did a test and was able to play an SD sequence on MC out through the Mojo SDI, then into the Kona 3 SDI input, upconvert it to 1080 and capture it as ProRes with FCP. Not a hickup.
Admittedly I have sometimes kept running an older OS/QT in order to keep within or at least close to what Avid supports.
Of course YMMV. I'd say that if you yourself don't have the ability to back-out of this setup by un-installing one program and creating a dual boot disk, then you should not do this in the first place.
- Larry Asbell
