misunderstandings about calibration
michele ricossa
on Mar 10, 2011 at 9:40:27 am
Hi to all,
I'm Michele, I recently started working as an assistant in a post production service.
I don't understand some things about color management and I wonder what is the correct workflow to calibrate a broadcast LCD monitor with this setup:
Mac Quad-Core Intel Xeon 2x 2,66 ghz
AJA Kona3
Monitor LCD BON BLM-basic240 connected via SDI
X-rite i1Pro
Thanks a lot.
Michele
Shane Ross
Re: misunderstandings about calibration
on Mar 10, 2011 at 5:54:16 pm
Start here:
http://www.lafcpug.org/faqwiki/index.php?title=LAFCPUG:_Getting_Started_FAQ...
If that is beyond you, hire someone. Which you should anyway...get a pro in there with a pro scope to calibrate the monitors. I do that every 6 months or so.
Shane
michele ricossa
on Mar 10, 2011 at 11:55:54 pm
Thank you for your reply,
I have already made monitor calibration with bars but I wonder if I can do better with the color sensitometer i1pro and understand if I can or not and why.
Thanks again,
Michele
Shane Ross
on Mar 11, 2011 at 12:28:16 am
[michele ricossa] "I wonder if I can do better with the color sensitometer i1pro and understand if I can or not and why."
Are you trained on how to use it and calibrate monitors? If not, hire someone who is. This complete "do-it-yourself" mentality has a line you can't cross. Certain things should be left to people who are experts in their field.
Shane
michele ricossa
on Mar 11, 2011 at 8:18:38 am
I'll keep your advice in mind!
Michele
