connecting An AJA kona 3 output to FCS Colour
Simon Fuller
on Jan 19, 2011 at 8:13:41 pm
I am hoping to get some advice. I have, in my edit suite a broadcast monitor that receives an output from Final Cut pro V 7. Is it possible to revive onto the broadcast monitor an output form Colour. this would be most handy for grading. Currently I am using the component out of the K3 for final cut pro 7 . I also have access to units SDI outputs if that helps. Any ideas would be grateful
Cheers
Simon Fuller Cameraman
http://www.simonfullerpictures.tv
Simon Fuller
Lighting cameraman
Richard Cooper
Re: connecting An AJA kona 3 output to FCS Colour
on Jan 19, 2011 at 9:50:42 pm
You bet, Simon.
In Color, just go to the Setup tab and they the user tab then chose your Kona Card in the video output drop down menu. This should send your video out through your Kona for proper monitoring.
Hope this helps!
Richard Cooper
FrostLine Productions, LLC
Anchorage, Alaska
http://www.frostlineproductions.com
Simon Fuller
on Jan 20, 2011 at 6:06:11 am
Thank you Richard, for your help. Much appreciated.
Simon Fuller
Camermaman
Simon Fuller
Lighting cameraman
