will Blackmagic SDI to Analog work with K3
Anhtu Vu
on Jan 13, 2011 at 2:55:27 am
I need to convert HD-SDI to Component HD and stereo balanced audio. Will the blackmagic SDI to Analog play well with the Aja K3 ? The same converter made by Aja cost almost double....is it any better ???
Jeremy Garchow
Re: will Blackmagic SDI to Analog work with K3
on Jan 13, 2011 at 3:04:54 am
The Kona3 has analog hd out if you need it.
Anhtu Vu
on Jan 13, 2011 at 3:15:27 am
I'm aware it has component analog out. I need to use specifically the SDI out to monitor as Smoke on Mac only uses SDI port on K3 and my monitor does not have the SDI input option board.
Anyways, back to my original question...anyone used Blackmagic SDI to Analog mini converters with K3 ??
Jeremy Garchow
on Jan 13, 2011 at 3:32:16 am
I still don't understand, but yes it will work.
All outputs are active all the time on a Kona. If the frame buffer is full, analog and digital will work.
walter biscardi
on Jan 13, 2011 at 3:11:49 am
AJA Kona 3 HAS Analog Component and analog audio output.
Walter Biscardi, Jr.
Editor, Colorist, Director, Writer, Consultant, Author, Chef.
HD Post and Production
Biscardi Creative Media
Register now for our Open House March 5
"Foul Water, Fiery Serpent" Winner, Best Documentary, LA Reel Film Festival...
Blog Twitter Facebook
Anhtu Vu
on Jan 13, 2011 at 3:19:25 am
Please read my 2nd post....i know K3 has component out BUT i need to use one of the SDI out port as Smoke for Mac ONLY support SDI in/out on K3
Btw, K3 does not have analog audio out just component.
walter biscardi
on Jan 13, 2011 at 3:25:03 am
[Anhtu Vu] "Btw, K3 does not have analog audio out just component."
Btw, yes it does have analog audio out. We've been using three Kona 3 for years.
[Anhtu Vu] "Please read my 2nd post....i know K3 has component out BUT i need to use one of the SDI out port as Smoke for Mac ONLY support SDI in/out on K3"
I still don't understand what the problem is here. You have two SDI I/O on the Kona 3. So one goes to your Smoke and then you send the Analog to your Monitor. Right?
Why do you need to convert the second SDI out of the Kona 3 to Analog and not use the Analog output from the Kona along with the analog audio?
Anhtu Vu
on Jan 13, 2011 at 3:39:57 am
it's quite simple, Smoke for Mac ONLY support SDI output NOT the analog component out. So in order to use an external broadcast monitor i have the option of using SDI-1 out or SDI-2 out from the K3, again the component out is not functional.
Since my PVM20L5 does not have the HD-SDI input optional board, i need to feed it Component HD...therefore the need for a SDI to analog converter.
Btw, the K3 does not have analog audio out, only AES, you get 2 channel of RCA output if you buy the optional K3-box.
walter biscardi
on Jan 13, 2011 at 3:50:35 am
[Anhtu Vu] "
Btw, the K3 does not have analog audio out, only AES, you get 2 channel of RCA output if you buy the optional K3-box."
You're the first person I've heard of that has the K3 without the breakout box. Not sure why anyone would not want to have that as it's much easier to connect gear.
Smoke is the first software I've heard of that disables the analog output on the K3. That's pretty dumb quite honestly on their part.
Any SDI to Component adapter should work since it's just a video feed. No clue on how the BMD will handle the image in terms of any sort of a delay to your monitor due to the conversion.
Anhtu Vu
on Jan 13, 2011 at 4:00:50 am
tell me about it...very odd that they disable the component out. I've been on-lining on Smoke for a few months now and for some things, it's brilliant, and others that are so odd, not user friendly, workflow killer and just plain dumb.
Anyways,thanks for the reply.
Jeremy Garchow
on Jan 13, 2011 at 2:37:18 pm
Does component out work otherwise?
Anhtu Vu
on Jan 13, 2011 at 3:27:49 pm
Yes component works in all other apps
Jeremy Garchow
on Jan 13, 2011 at 3:46:27 pm
[Anhtu Vu] "Yes component works in all other apps"
Sorry for my naiveté.
Jeremy
gary adcock
on Jan 14, 2011 at 2:28:13 pm
[Anhtu Vu] "it's quite simple, Smoke for Mac ONLY support SDI output NOT the analog component out."
This is correct.
the current Smoke for Mac installs disable the Analog outputs on the Kona Card.
gary adcock
Studio37
Post and Production Workflow Consultant
Production and Post Stereographer
Chicago, IL
http://blogs.creativecow.net/24640
Bob Zelin
on Jan 14, 2011 at 3:18:38 pm
Anhtu -
this is the answer to your question -
YES.
ANY SDI to Analog converter from ANY MANUFACTURER - Cobalt Digital, AJA, Blackmagic, Leitch, Edirol, ANYONE - THEY ALL WORK. YES, THE BLACKMAGIC WORKS.
Is that clear ? Now, if you can tell me who to threaten at Autodesk, so they will activate the other outputs, I would appreciate it.
Bob Zelin
